how do i know were to set base timming?
Old May 18, 2006 | 09:28 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
how do i know were to set the base timmin on my 91 tpi motor...can i look at the bin file and tell? may be a stupid question and im sorry but im just not sure....thanks ryan
Old May 18, 2006 | 11:31 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I believe TPI cars were set at 6* stock. The VECI label on the underside of the hood near the latch should tell you for sure.
Old May 19, 2006 | 01:07 AM
Car: 92 1500p\u 2wd
the motor is in my 92 fullsize truck and it has a bigger cam ect.....i just wanted to find out what i need to set my base timming to....can i find out by lookin at my bin file or should i just set it to 6* befor TDC?
Old May 19, 2006 | 09:17 PM
Car: 92 1500p\u 2wd
well i put the base timmin to 6 BTDC and took it for a drive...took a log and it knocks like crazzy i can hear it pinging when i get on it the knock counts just clime...last spring was my last log and it would not knock near as bad when i got on it maybe one or 2.....well me base timmin was advanced befor i put it a 6* today...why would it knock less when it was advanced? when i first checked it with the plug unhooked the notch on the balencer would jump all around a few *s and when i set it back to 6* BTDC and then checked it it was nice and still...not sure why this is also? im lost...am i doin somthin wrong?
Old May 20, 2006 | 05:13 AM
ede's Avatar
ede
set the base as far advanced as you can with out ping or starting problems. 36* total is a good point to aim for
Old May 21, 2006 | 12:27 AM
Car: 92 1500p\u 2wd
alright when im readin the data log....it says my timming is about 22-26 at cruze so you say it would be best to try to shoot for this to read 36?
Old May 21, 2006 | 05:02 AM
ede's Avatar
ede
you want your total timing, base + vacuum + mechanical ( or eletrical) to be around 36*
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
TheExaminer
Aug 19, 2015 10:07 PM
