Heads for a 350
Old May 19, 2006 | 04:07 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Heads for a 350
I ahve a 72 Truck block that i just got for $50. I want to build a 383 and am looking for high 300 low 400 hp ratings. with a good port polish and angle job could this be done with stock 350 heads? if not what are good aftermarket heads that could get me there for cheap. (ie. no AFR or brodex kind of thing)
Old May 19, 2006 | 04:49 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The best bang for the buck aftermarket heads I have seen are the RHS vortec heads. They flow just as good as the high end aftermarket heads till .500 lift then the other heads take over. For the power your looking for the AFR and heads of the like would be a waste since they really shine in higher lifts you will never use.
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what casting # are the heads? It can probably be done, but it'd be difficult, and not terribly efficient.
edelbrock or vortec heads would be a good thrifty choice. Certain factory heads would work, 083's probably. The ones on your '72 block (993s or 882s?) probably wouldn't.
Old May 20, 2006 | 12:21 AM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
What about like the LT4 heads or another head like that? if i go vortec heads do i got to do vortec intake too?
Old May 20, 2006 | 02:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes, vortec heads require a vortec stlye intake. Ltx heads are reverse cooling and will not work without modifications.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
