These heads any good
Old May 20, 2006 | 08:35 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
would these head be worth getting a big port and polish and maybe a angle valve job on, i am looking for high 300 low 400 HP. here are the specs?
Cast # 333882 YR 1970-80 Block 350/400 intake 1.94 exhaust 1.5 CC 76cc
Any good?
Old May 20, 2006 | 08:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Any stock GM head, expecially from the 70's with 76cc combustion chambers, is not a horsepower head. They're smog heads. Trash 'em.
Old May 21, 2006 | 10:28 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
How much do you think that those heads are holding these engines back?
Old May 21, 2006 | 11:32 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Don't even bother with the 882 heads. You're wasting your time. Get some common "416" 305 heads, port them yourself and upgrade to a 1.94x 1.60" valve combo. Pin the rocker studs and you're all set.
Old May 22, 2006 | 12:16 PM
Engine: 388 Carb
Axle/Gears: 4.10
Ok, on the drivers side of the engine it has the 333882 heads and on the passenger side it has the 462624 casting number, i looked it up and it says that it has the same 76CC but are the flow numbers the same, thank god i am getting new heads soon but till then whats going on??
Old May 22, 2006 | 02:56 PM
F-BIRD'88's Avatar
Those two heads are functionaly the same. Both are crappy.
Worst and worstest.
Bolting on a set of vortecs in place of those heads would get you a minimum of 75hp and a ton of torque even with a mild cam. Yes they are holding you back. The only fix is to march them out to the curb and get better heads.
Old May 22, 2006 | 05:55 PM
Engine: 388 Carb
Axle/Gears: 4.10
I am getting new heads shortly but and i hope you mean that i will see an increase of 75 not a minimum of 75 lol but yeah i hope so... "those heads would get you a minimum of 75hp."
I was thinking about getting a mild crane cam i forget the number but i have it written down somewhere... I want to drive it as well as be able to beat a few kids here and there if i wanted to.
Old May 22, 2006 | 06:12 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
While on topic. I have a couple of these crappy heads laying around. Does anyone know of any good things to do with them? Like say a coffee table or something. Has anyone made any fantastic furniture out of them here? I wasnt sure if they would even be worth trying to transform into something else.
Old May 23, 2006 | 08:53 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
ok two more questions. I have a 305 but its a TBI, what kind of power could i get out of these with a p&p and bigger valves # is 14102187. what about zz4 heads? and if i got these would a zz4 hot cam work in my old block? thanks alot guys
Old May 23, 2006 | 09:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I made 240 RWHP with stock 187 castings on a 305. What is a ZZ4 Hotcam? The ZZ4 cam and LT4 Hotcam are different pieces.
Old May 24, 2006 | 12:59 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yard Art.
There's a guy in town who had several trashed (but painted up nicely) old Flathead V8's in his lawn.
Looks cool driving by, but to me just more weed eating around the edges.
Coffee table stand is a good idea, but you have to have at least 3 or 4 sets to be able to pick your beer off of without leaning too far forward. Not really an issue until you go to move the darn thing.
Old May 25, 2006 | 03:54 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
well where could i get with some ZZ4 heads? they worth the money
Old May 25, 2006 | 04:04 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
zz4 heads are 113 casting heads. I saw a set on ebay brand new for 530. I think scoggin dickey sells them for 575 ish. Decent heads 58cc chambers/1.94 valves and the best part is they are aluminum so you can run higher compression.
Good for a 305...not sure if id settle for 1.94 valves for a 350
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
