Fuel pump relay
Old May 22, 2006 | 06:25 AM
Scotty27's Avatar
Car: 1989 IROC
Transmission: t5, wanna be a t56 when I grow up!
Axle/Gears: Whatever stays bolted on behind me!
Fuel pump relay
Hey all,
not necc a 3rd gen question, but chevy nontheless. You guys have helped me out in the past so Ill throw a neew one at ya...
How common/uncommon is it for a fuel pump relay to go bad?
For obvious price reasons, Im hoping its that, not F/P, which doest prime or energize when key on.
1998 Blazer if needed!
Thanks....
Scott
Old May 25, 2006 | 09:44 AM
chevyschofer's Avatar
Car: 88 iroc
Engine: 5.7 350TPI
Axle/Gears: 373'S
EASY FIX
NOT VERY OFTEN, BUT YOU CAN JUST HARD-WIRE(BYPASS) TO FIND OUT FOR SURE.
Old May 25, 2006 | 05:25 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Fuel pump relay isn't that expensive($15 to $35)depending on where you buy it.If the wiring on your '98 Blazer is like my '95 Jimmy(GM changed the harness but I'm not sure if it was in '98 or '99)the relay is in the glovebox.And if the wiring is the same there are 3 relays in the glovebox that interchange to see if the fuel pump relay is the problem.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
