engine problem??
Old May 24, 2006 | 09:52 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
engine problem??
my engine is as 350 with a so so carb. Recently ive put a new trans with a full manual shift kit, stall 2200-2500rpm, z-pack clutch kit, biger valves, super servo....Trans shift realy good but tonigh I had a drag event. First race was a total destruction of the other car....second race, first gear was good shift at 5500 , second gear am at about 4500-5000 the engine fall on its face at 3000 with still WOT....so i shift in third and can go past 3000.... .
the car was starting to get realy so I park it......later thrid race, first gear was good, second good, third fall on its face at 3000.....so on my way back i stop and lock under the car and my cat is glowing red....and my car smell gaz like never before.
do a cat can cause this......and on my way back i had no problem
i was waiting 30 min between run on idle in the waiting line
Thanks Seb
Old May 25, 2006 | 09:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why did you leave it idling in the staging lane? You probably had vapor lock. How is the fuel being delivered to the carb?
Old May 25, 2006 | 05:53 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
cause its hard to start when hot realy slow cranking.
for the fuel its 92 oct with mec fuel pump(geting old)
Seb
Old May 25, 2006 | 05:56 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
If your cat is glowing red, it's probably plugged. Are you having problems starting it? Does the idle really suck? If so, you might want to punch a hole in the cat until you can get it replaced.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
