Got my car back a week ago. Now codes 41 and 42
Old May 22, 2006 | 05:35 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Do these codes in combination mean anything? the car seems like its running fine. the only thing is it bogs a little bit in o/d if you quicly let off the gas, but it stops after about 4 bumps. its a tpi 350 (crate motor) with a 700r4. thanks a lot guys, im a little worried cause i just spent a lot of time a money fixing this (the mechanic fixed it, not me).
Old May 23, 2006 | 12:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like an ignition or wiring problem to me.
Old May 23, 2006 | 12:46 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Codes
Codes 41 is Cylinder select error faulity or incorect MEMCAL
Code 42 Electronic spark timing est circuit
Old May 23, 2006 | 09:26 AM
ZZ4 86 Z28's Avatar
well i read what the codes mean, but i was wondering more specifically what would need to be fixed if anything. i just got the car back and the mechanic replaced a bunch of distributor parts and spark plugs and reset the timing. could he have messed up somewhere?
specialized
Jun 18, 2022 09:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
gwade12
Aug 8, 2015 08:17 AM
