Pully set up for electric water pump
Old May 23, 2006 | 02:20 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
What choices do we have for serpentine belts and electric water pumps? I do not want to use the mez. electric pump with the pully on it. I want as less as possible. Is there another way to run it? Even a simple picture in paint would work.
Old May 23, 2006 | 08:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Companies like March offer serpentine kits for electric water pump setups.
Chevy Small Block Electric water pump Serpentine brackets
I have my alternator mounted lower on the passenger side and a serpentine belt runs from the crank, under the water pump and to the alternator. That's the only thing I have running off a belt.
Old May 29, 2006 | 11:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
could you do this with TPI belt setup and maintain any of the smog stuff/ac?
i want to go electric pump sometime to try and squeeze out as much power from my stock L98 as possible as part of a goal to go as fast as possible. but i'm probly gonna junk my AC and smog stuff eventually. this is IF my first slick passes show promising results.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
