Noob question about exhaust sound with headers?
Old May 23, 2006 | 05:39 PM
drns4123's Avatar
i've got stock everything on my car and want to swap in shorty headers while keeping the stock exhaust. is it going to make my car much louder? or will it just sound deeper? kinda worried because cops here hassle everyone for loud exhaust. 350 tpi engine
Old May 23, 2006 | 05:41 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Deeper note, generally a touch quieter at idle. Also depends on everything else you've got. I hope you go with a better catback soon after headers
Old May 23, 2006 | 06:45 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I have a reverse question to that...I kept my stock exhaust manifolds as I have a daily driver. I want to add exhaust later and want to know which mufflers will work best with stock manifolds. Same motor...350 TPI.
Old May 23, 2006 | 06:49 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Honestly, it really doesn't matter. You won't see more than a 5hp gain even if you hacked your exhaust off after the y-pipe. The stock exhaust manifolds and y-pipe are the most restrictive choking exhaust that GM has ever used, and it only gets worse with swirl-port heads!
Old May 23, 2006 | 07:20 PM
Car: '87 Trans-Am
Im not after power, more after a good sound...will the manifolds affect the different brands sounds very much?
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 7, 2015 09:55 PM
