Push rod question
Old May 24, 2006 | 08:24 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
Push rod question
Just pulled off the valve covers to my engine. Some rockers were loose and some of the pushrods had enough room to spin. I know they are not supposed to spin when first installed and the rocker nuts are tightened...Do they naturally loosen and adapt to the camshaft? Is it normal that some of my rockers and pushrods were quite loose?
Old May 24, 2006 | 09:19 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
no its not normal...
It could be that they were either not lashed properly to begin with or that the nuts have backed off or the studs are pulling out of the heads.
Old May 24, 2006 | 09:31 PM
hihighost's Avatar
Car: 1987 Camaro
Okay, great. I was trying to find out where a constant clicking noise was coming from when the engine was running, and perhaps the pushrods and rockers being so loose might have been cause for the noise.
Old May 24, 2006 | 09:33 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
definately going to be the cause of some top end chatter!
Old May 25, 2006 | 09:58 AM
hihighost's Avatar
Car: 1987 Camaro
Well it would click constantly, whether I was idling or revving the engine. And the clicking would get faster or slower as the RPM's went higher or lower.
Old May 25, 2006 | 10:04 AM
Yes misadjusted rockers will tick.
Did you adjust them yet?
That's the first thing you should do. Forget about the "twisting with your fingers" crap, or whether they're "supposed to spin" or not, that's all nothing but the short road to a PITA. Just crank the motor up, back each one off one at a time until it ticks, and re-tighten it slowly until it quits; do all 16 like that as quick as you can; then shut it down and add your desired preload (I'd recommend ½ turn).
Then if they still make noise, maybe it's time to ask what's causing it.
Old May 25, 2006 | 10:33 AM
85SILVERBULLET's Avatar
Car: 1985 TRANS AM
Engine: 383 SBC
are you running solid or hydro.???
Old May 25, 2006 | 10:37 AM
hihighost's Avatar
Car: 1987 Camaro
They're solid. I'll get to finding out whether the rockers truly caused the clicking, but for now I'm replacing the head gaskets so It'll be a week or so before I put everything all back together and readjust the rockers.
Old May 25, 2006 | 10:49 AM
They're solid
You sure?
What cam is in it?
Old May 25, 2006 | 01:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
uhh yea, usually people don't use a solid cam unless they really know what they're doing, and are very familiar with adjusting lash (or else they will quickly become familiar with it...)
I'm guessing it's a hydraulic lifter setup right? If it's a stock cam it's a hydraulic lifter, follow sofa's advice, and go from there.
Reborn756
Sep 4, 2015 03:42 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
