Tach Trouble
Old May 25, 2006 | 07:24 PM
83 Z28 Camaro's Avatar
Car: 1983 Z28 Camaro
Engine: V8 with Cross Fire Injection
Tach Trouble
The Tach in my 83 CFI, 700R4, Z28 Camaro is way off. the tach redlines when i am idle. there seems to be something like a capacitor mounted on the firewall behind the distributor it is in line between the tach connector on the distributor cap and the wire leading to the cluster. whatever it is it looks fried. My question is what is that piece and where can i get a new one. Also is it possible to just bypass it. I know it isn't the cluster because i have two of them (both stock) and they have the same problem. We have had no luck trying to find this part at the local auto store (advance Auto Parts) and the Dealer and still do not know what it is called.
Old May 25, 2006 | 10:49 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Yeah this is a common problem for these cars, and the topic is widely discussed. Try searching to narrow down your answer, but I would look for a new tach or the capacitor that you need at a junkyard since I dont think these are manufactured anymore.
$750 L98
Feb 1, 2025 02:25 PM
mrbird
Oct 20, 2015 03:43 AM
Eric-86sc
Sep 28, 2015 11:37 AM
Lmancha96
Sep 25, 2015 08:11 PM
TrevinE
Sep 14, 2015 03:20 PM
