87 iroc z fuel pump
Old May 26, 2006 | 07:08 PM
Todd Chastain's Avatar
Car: 87 iroc z28
Engine: 5.7 TPI
87 iroc z fuel pump
My fuel pump is dying. 30 psi at the schrader valve. What is a good replacement pump ? I'm thinking about just replacing with a factory pump cause I don't want to fool with the computer right now.
Also, any idea how much it cost to have it done the right way, buy a mechanic.
Old May 26, 2006 | 07:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
pump is ~100, $300 labor, $400 is common.
It's not all that tough, more time consuming then difficult. If you knew how to test it, and know what a "shrader" valve is, you can do it yourself.
factory pump is best for a factory engine.
Old May 26, 2006 | 07:31 PM
Car: 87 iroc z28
Engine: 5.7 TPI
It's a big task. Don't really feel like wrestling with the exhaust pipe or muffler. Seems like everytime I take on such a project I have to take stuff off, put it back on and take it off again because I screwed something up. I do most of the work myself with anything else, I dread this one.
Old May 26, 2006 | 07:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, it's a hassle, but you don't need special tools or anything. A friend and a case of beer with an afternoon will save you $300. I'm cheap, so that's what i'd do.
Old May 26, 2006 | 07:48 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
