91 FIREBIRD STARTING ISSUES
Old May 27, 2006 | 09:39 AM
FWNSBRD's Avatar
I have a 91 pontiac firebird. The other day after a oil change the car does not run after shutting off the engine. You can drive the car all day and no ruff idling or any issues but once you park the car and turn off the iginition the car will not start for another 4 hours and then will run fine. I am having a heck of a time figuring this out. Everyone said fuel filter, that is replaced and now fuel pump but that is not making sense to me any suggestions. I tried seeing if there were any faults on the ecm and there were none.
Old May 27, 2006 | 02:06 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
does the starter turn at all? sometimes heat from headers can hurt the starter
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Could be an ignition module acting up... You need to do some diagnosis when the problem occurs.. Step one would be to verify that you have a distributor reference pulse during cranking.. Look for a purple/white wire coming off of the distributor, or at the ECM (B5 for TBI, BD8 for TPI/V6). Set your multimeter to AC voltage, and measure that wire (reference to ground). You should see somewhere around 2.5V during cranking. If you don't have that, then the ECM won't ever pulse the injectors, and you won't get any fuel. If you've got that, and you've got fuel pressure, you need to double check the basics...
EDIT: I guess we should clarify here.. It does crank, but it won't fire??
Old May 27, 2006 | 06:54 PM
FWNSBRD's Avatar
Well have it in for diagnostics at a shop but they have had it all day and can not come up with any solutions. I was told by a friends mechanic and not guess should have just replaced the ignition module like told and would have been on my way. So guess I wasted 100 dollars on diagnostic testing.
Yes the car wants to start, the engine will turn over just not getting fuel I guess and if that is the cause then great. Just does not really say anything in the Haynes manual about the ignition module about completely what it does.
Thanks for confirming what we suspected.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
