Burned Piston Rings and New car
Old May 28, 2006 | 12:01 PM
88ChevyThunder's Avatar
Car: 88 Chevy
Engine: TBI 350
Transmission: 700R-4
Axle/Gears: Jegs Axle and 343 gears/Posi Unit
Hey guys I am going to buy this 3rd gen camaro from a guy for 500 bucks its a carbed out 350 with a tremec T5. How much would it cost me to fix the burnt piston ring problem? ? Or if I could do it myself or if anyone from the board would be willing to help me do this? I live in the SW houston area in alief. Thx guys
Old May 28, 2006 | 12:08 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Will probably cost about the amount you bought the car for. The shop will need to remove the engine out the car, remove oil pan and head to get the piston out then reassemble. Check theregional board here and see if someone in your area can help you out.
Old May 28, 2006 | 12:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Even worse, it should be honed for new rings, which means disassembling the whole engine.
Old May 28, 2006 | 02:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Many people think they can just throw new rings in a burnt up motor and expect them to seat. Well its just highly likely they arent going to seat worth a crap and you will end up doing the job a second time!
Old May 29, 2006 | 09:57 AM
LedHeadRed's Avatar
Car: 1990 Corvette
Engine: 355cid
Transmission: ZF-6 speed
Axle/Gears: stock 3.33
its will cost a helluva lot more than $500. all said and done with engine removal/install, machine shop work, parts, the many hours of associated labor, it will be about $3,000+ .
Old May 29, 2006 | 11:16 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Just build a new motor for that car and toss it in when it's done
hectre13
Dec 11, 2023 08:14 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
