Opinions on Vortec Heads and Manifold
My plan was to find a set of stock heads and port/polish them for my 305TBI. I was talking to my friend and he suggested I just get a set if GM Performance Cast Iron Vortec heads along with the GM Performance Vortec TBI Intake. The heads are $250 a piece and the intake is $330, so $830 for the whole deal.
What do you guys think of this? Should I hold out for aluminum heads or do you think cast iron is fine? Anyone have any experience with these products? If you don't like them, do you have any suggestions for something else?
Also, these have a combustion chamber volume of 64cc, but the L03 needs 58cc correct? Would I just get these milled down?
Here are the two product links:
JEGS High Performance - GM Performance Parts Cast Iron Vortec SBC Heads
JEGS High Performance - GM Performance Parts Vortec TBI Intake Manifold
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Chevy High Performance did this a couple years ago, but I dont know how they did it. By milling the heads down that much, you are guaranteed to mess up the accessory bolt holes on the front so your accessories wont bolt on. They put in a mild 208 camshaft too, and lots of tuning, and ended up with 257 HP at the wheels
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If it were my engine, I would put the money towards aftermarket heads that don't require a new manifold. Especially if it's going to cost that much.
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Dart iron eagles can be had for nearly the same price, and you can retain your stock manifold, so in the end you might even save money. You may also be able to buy them in a 58cc version.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
