These plugs are indicating a rich mixture... right?
Old May 29, 2006 | 12:40 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I know the truly ideal way to read spark plugs is by cutting off the threads and examining the insulator, but I hope this picture shows enough information. I'm in the process of tuning my idle and I think I'm running a bit rich.
I started with a new set of ACDelco R43TS plugs and ran the engine at idle for about ten minutes each time. Between tests I cleaned the plugs with brake cleaner. The upper picture shows the first run with my original idle fuel calibration. I leaned the mixture out a bit via the EPROM, but for one reason or another, the MAF sensor was picking up more airflow and thus ran the engine in a richer state the second time around (lower picture). I think the two images demonstrate this, but I just want to be sure that I'm seeing a less-than-ideal situation here.
This is a new engine with less than 1000 miles, so the little bit of oil on the plugs appears normal. I have not run the engine at anything other than idle with these plugs.
Attached Thumbnails These plugs are indicating a rich mixture... right?-plugs-5.29.06.jpg
Old May 29, 2006 | 01:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
from the pictures it looks to me like all but #4 are lean...
Old Jun 3, 2006 | 01:34 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
These plugs do not show a rich setting, if it was running rich the plugs would be black and sooty.
You really can't get a reading from idling, I would install them, do some driving and take some more photos and put 'em back on here.
Old Jun 3, 2006 | 05:42 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Yeah, I'm starting to see that now... I guess the oily residue was confusing me. I knew I had a rich condition at idle and was expecting to see some more carbon. After some normal driving they looked alright. Guess I'll just have to use a wide-band O2 to really nail the idle mixture.
Jlanz55
Sep 9, 2015 09:09 AM
Jk_Under
Sep 8, 2015 08:13 AM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
89 formula TPI
Sep 7, 2015 11:06 AM
