Cooling Fan & Blower Fan Not Running
Old May 29, 2006 | 05:48 PM
bonacci1's Avatar
Car: Lumina Z34
Engine: 3.4 Twin Dual Cams
Transmission: 460TE
Last week my sons 92 Camaro RS 305 TBI cooling fan and blower fan stopped running. All fuses are good. I went out and bought a new relay and still nothing. Any advice?
Old May 29, 2006 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like two separate issues. IIRC, the cooling fan comes on with A/C and/or head temp, which has nothing to do with the blower motor. Which relay did you replace?
JamesC
Old May 29, 2006 | 05:59 PM
bonacci1's Avatar
Car: Lumina Z34
Transmission: 460TE
Relays
I did the one by the blower motor first. Started the car to get hot and nothing. Put the original relay back in and swapped the one on the drivers side firewall. Still nothing.
Old May 29, 2006 | 11:09 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Is the A/C compressor clutch pulling in?If it's not then the A/C fuse could be blown.Did you pull the fuses and check them?I've had a fuse look good that had shorted near it's base where you couldn't see it.There's also a relay for the compressor on the driver's side firewall(I believe).Could also be a loose connection or a bad ground.
I take this is a single fan model.Have you checked to make sure the fan motor is good?Again the connections are a good place to start.
Old May 31, 2006 | 07:09 PM
bonacci1's Avatar
Car: Lumina Z34
Transmission: 460TE
Problem Solved
Took the car to the Dealer yesterday evening.
They replaced the ignition switch in the car and everything is working again. Try to remember incase you run into this problem.
Old May 31, 2006 | 09:23 PM
coolram62's Avatar
Engine: LU5 305 CFI
That's interesting.When you were having the problems would you able to start and drive the car.Just curious.
Old Jun 1, 2006 | 03:33 PM
Treadin' 92's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: 700-R4 Vette Servos
Yes car started fine just no power to the fans
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Leggman1
Aug 6, 2015 04:15 AM
