Anyone ever see a timing tab break off?
Old May 30, 2006 | 10:58 AM
CamaroX84's Avatar
I went to check my timing yesterday, and I noticed that there was no tab on my timing chain cover! It must have happened in the last month because it was there at the beginning of the season. Any way I can temporarily make a marking as a reference point? I've never seen this happen before.
Old May 30, 2006 | 12:11 PM
Damon's Avatar
Can't say I've had the problem before. Possible, though- a spinning dampener that grabs onto something and flings it around could probably rip the tab off.
Old May 30, 2006 | 12:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yea, fairly common. they only have a little tack weld holding them on.
you can pick up an aftermarket (mr gasket and whatnot) tab that bolts on using the same bolts that hold the timing cover. their only a couple bucks.
Old May 30, 2006 | 12:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not if your original timing pointer was in the 12:00 position.
Old May 30, 2006 | 12:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yea, sofakingdom brought up that little issue a while ago.
buy one, $2-5, bolt it on, then turn over your motor by hand, and verify TDC through the #1 spark plug hole. If TDC lines up with 0 on your tab, done deal, otherwise, you can just know that you're 35* off or whatever, and account for that, or buy an adjustable pointer, and point it to the mark on your balancer.
Old May 30, 2006 | 01:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
An adjustable timing pointer wouldn't give you enough range, but you can always scribe a new line on the balancer, or use a timing tape, or a balancer cover.
midge54
Dec 27, 2019 04:14 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
MY87LT
Aug 17, 2015 08:43 AM
cstrobel65
Aug 15, 2015 10:19 AM
Poncho92
Aug 7, 2015 08:15 PM
