Wont Idle.......HELP
Old May 30, 2006 | 01:50 PM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
Hi Guys, stock 305 TPI.
Wont start, unless tou give it fuel, and it runs perfect if you keep the RPM above 1200, less than that and it dies right away without any sputtering. Unplugged idle air and exact same thing, and replugged it in and still no change.
used the code reader, code 12, all normal.
Any suggestions on what may be happening?
Old May 30, 2006 | 02:48 PM
z28b88's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8l V6 MPFI
Transmission: 5-speed
i don't know about the 305 but on my 2.8 theres a screw on the throttle body that you can just tighten and this just gives it more air/fuel so that it idles where you want it to idle...that fixed my problem and it was doin the same thing yours is...hope it helped but like i said it may be different on the 305
Old May 30, 2006 | 03:40 PM
Car: 1991 Z-28
Transmission: 4L60
must go see if that is it!
Old May 30, 2006 | 03:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like timing is off
Old May 30, 2006 | 04:55 PM
Car: 1991 Z-28
Transmission: 4L60
Found the problem...there is a vaccum hose that goes from the throttle body to the valve cover on the pass. side, he was let go, so plugged him in and
Tks guys
Old May 30, 2006 | 05:08 PM
z28b88's Avatar
glad to hear you fixed the problem...
