HELP!!! Need to fix before Wed. night race
Old May 30, 2006 | 05:24 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
I just installed a holley afpr and the wheel on the fpr is hitting the plenum. Do i grind some metal off the wheel or off the plenum? What tool should i use? And is there a better way?
Old May 30, 2006 | 10:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I put a Holley on mine with the stock plenum and didn't have a prblem...is your bolt all the way out? If so, run it in until it clears, then check fuel pressure.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
84 TA NV
Sep 6, 2015 08:02 PM
Amillionoh7
Sep 5, 2015 11:44 PM
