testing distributor for no spark
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I removed my distributor to shorten the mechanical advance slot, this required a complete disassembly.
Now I put it back in the car, and it won't start up. It'll crank nice and fast, but it won't back fire, chug, nothing. I'm assuming absolutely 0 spark.
I've got power at the power input plug going to the distributor cap. I'm assuming somewhere between power input, and spark plugs, there's a missing link.
Can anyone give me some places to probe with my multimeter to check? I don't have a helper here, so i'm stuck doing this solo, if possible.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You should be able to see pulses on the tach wire with the voltmeter. If you can, then connect a plug wire to a calibrated spark tester or gullible younger sibling.
Car: 1982 Trans-Am
pulses on the tach wire, while cranking right?
then crank the motor over, while holding a plug ground strap, against the block, and watch for the sparks?
I'll have to try these when my brother gets home...
I had a brainwave:
there's a collar, the slides over the center shaft, press fit, this collar holds the rotor mounting tab at a certain height. Now I had to remove this stuff to enlarge the slots. When I pressed the collar back on, and therefore set the height of the rotor, I didn't really pay attention to this. There was slop in rotor mounting "plate". in reference to the weights mounting plate.
I just tore down the distributor, and pushed that collar back up, to take out any slop, now ~.030" vertical slop. But now the rotor sits a bit lower. The teeth on the center shaft are ~1/8" lower then the stationary teeth. (top surface to top surface)
Is there a spec for these dimensions? I think this is most likely my problem, since I didn't R&R the coil, capacitor, etc, no wiring changes in the distributor...
I was hoping to drive the car to an exhaust shop tonight so they could modify my new y-pipe tommorow
I had a brainwave:
Car: 1982 Trans-Am
hmm, well that musta been it... I reset that height, turned the motor back to TDC on #1, dropped in the distributor, made sure rotor pointed to #1 and it fired right back up
Hey Chris, is your 383 in the car and running yet? I noticed you got a 305 TPI 5 speed, that your new daily driver?
Engine: 383 Carb
Transmission: 4L60
No, it looks so shiny and clean on the stand that it would be a waste to put it in a car.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
And i was right. After a few hours run time the rubber seal at the front of the pan (between the timing cover and pan...) split in half and now ive got a slow drip!
Oh well, yank the motor again i guess...
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
