Fuel Pump
Old May 31, 2006 | 12:40 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Fuel Pump
I've got a Holley electric fuel pump that I need to install on my car. Motor is a carbed 400 sbc. Do I just plug off the return line (smaller one) and hook the pump up to the feed line (larger one) and I'm good to go? Do I need a regulator?
Thanks.
-Greg
Old May 31, 2006 | 12:52 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
What pump is it?
99.99% of electric pumps will need a regulator.
Old May 31, 2006 | 01:13 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
yes you can block off the other line(s).. i did it for my car.. just one line to the pump and out to the carb.. carbs dont need a return line so just hook it up and your ready to run.. and you will most likely need a regulator.. pressure adjustment is always helpful when tuning..
Old Jun 2, 2006 | 12:20 PM
Engine: 400
Actually, if anyone can identify and give me some info on my pump that would be great. This is stamed on the bottom: Holley L-6145-2. I also see 3044 stamped on the bottom. I can't find any info on it.
Old Jun 3, 2006 | 01:38 AM
5678TA's Avatar
Car: 1984 Trans Am
is the pump red by any chance??? holley only makes one red electric pump and i found a hit on ebay.. the PN was L6145-24.. closest i could find to your L-6145-2.. it had what looked to be a red sleeve over the top of the motor.. there is a picture on the bottom..
well the specs i found are as follows:
Flows 97 GPH (free flow). Flows 71 GPH at 4 PSI. Maximum pressure is 7 PSI. Motor draws only 2 Amps current. 7-1/2 Amp fuse recommended.
it says that a regulator is not recommended for that pump. better for you.. but the down side is that it will only supply enough fuel for around 425hp max.. with the 400sbc you're runnin, i think you should opt for a blue or even black pump.. the blue will give you support till 550hp and the black will go up to 750hp.. both the blue and black will require a regulator..
Old Jun 3, 2006 | 11:12 PM
Engine: 400
Cool! Thanks for the info. That pump does look similar to mine. Since I'm in college and on a tight budget I'm just gonna run with this one. My motor prolly won't get any more mods, and I'm not pushing over 320 horse.
Old Jun 4, 2006 | 02:55 PM
5678TA's Avatar
Car: 1984 Trans Am
sounds good.. you should be fine..
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
