whats the best oil to use for new engine break in?
Transmission: A4
I have heard from a few guys that I should run a motor oil that does NOT have any detergants in it during the first few thousands miles on a new engine. What type of oil is out there that doesnt have this detergant?
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
You'll be find with just a standard motor oil. I would however recommend a straight 30w for the first 500 miles. Then switch to a multi-weight oil such as 5w-30. Make sure to prime the engine before you start it.
Transmission: A4
I just primed it with a compressor and a pressurized canister that holds 5 qts of oil. I used Mobil 1 5w 30 for the priming. SHould i take that oil out and buy some 30w oil instead?
Car: 1992 Camaro RS
Axle/Gears: Stock
I think I read somewhere that you're supposed to run a synthetic blend for so many miles with a new engine. Then switch to full synthetic.
Call up the oil and/or engine manufacturer to be sure.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
yes, synthetic is not goot at all for breakin and can damage your motor, depending on your configuration .
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you CAN'T run synthetic on a brand new motor. Only after 500+ miles. Your rings won't seat and your cam will go flat. Your headlights also won't work
ok, not the last one....
Use a can of GM EOS with your first jug of oil.
ok, not the last one....Use a can of GM EOS with your first jug of oil.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
How about none of the above. New conventional motor oils lack certain additives that come in rather handy and synthetics are too good at their job to allow proper break-in (in flat tappet cam engines- there is still debate over the rings on roller cam engines, etc., - that's 'nother bag for another thread).
I like diesel oils like Delvac (NOT Delvac1) or Rotella T (NOT the synthetic or blend) for break-in. Or a conventional with the GM additive... but The Delvac and Rotella are rather easily had.
Transmission: A4
well there is already 5w30 in the engine from priming it. Is it worth it to drainit and put regular 30w in or just go with it. The oil is not synthetic
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
