Turning over engine by hand
Old Jun 1, 2006 | 06:37 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I see this all the time, how is this done?
Old Jun 1, 2006 | 06:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can get a tool to bolt to the balancer that you can turn with a wrench or breaker bar, or you can get a tool that turns it by the flexplate/flywheel teeth. Some people turn it by the balancer bolt, which how a lot of balancer bolts get broken off in the crank snout.
Any way you do it, it's a lot easier if you take the plugs out first.
Old Jun 1, 2006 | 07:11 PM
I guess this is to relieve pressure right?
There was no real reason for this question, just wanted to know how it was done.
Old Jun 1, 2006 | 09:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right, otherwise you're fighting compression while you turn it.
You can also bump the engine over with the starter, either with the ignition switch or with a switch clipped onto the starter.
Old Jun 2, 2006 | 12:47 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I wouldn't recommend turning by the balancer bolt even though its easiest way. I do it but also take all my plugs out and usually have my plenum off.
Still not good...
Old Jun 2, 2006 | 07:52 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
[QUOTE=CamarosRUS]I wouldn't recommend turning by the balancer bolt even though its easiest way. I do it but also take all my plugs out and usually have my plenum off.
QUOTE]
There is a tool sold at some automotive stores that you install on pulley attached to your balancer. You just remove the 3 bolt on the pulley (make sure belt is off) install tool and install the 3 bolts back on the pulley. The one I have allows me to use a 1/2 drive or a 1" socket to turn the engine. As CamarosRUS has stated, it would unwise to turn the engine using the actual balancer bolt.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
BrianI
Aug 9, 2015 11:52 AM
