quick torqe question
Old Jun 2, 2006 | 08:11 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
I am to the stage in my motor rebuild where i gotta torque down the oil pump. I screwed this part up last time and it cost alot of money and time, so i thought i would ask yall a few things before i proceeded.
1. What is the torque on the single bolt that holds the oil pump to the main cap that it bolts to? I am confused about what my book says and dont wanna get it wrong.
2. Are there any gaskets on the oil pump? I dont think so but i thought id make sure.
thanks in advance for your reply.
Old Jun 2, 2006 | 08:46 PM
Damon's Avatar
No gaskets. Metal to metal. 65 ft/lbs.
Old Jun 2, 2006 | 08:48 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
thanks
thanks for the quick reply. I thought so on both but i did something wrong last time and it worked itself loose. thanks agian
Old Jun 3, 2006 | 02:09 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think they recommend using oil on the threads, or ARP bolt lube.
If yours managed to work loose, perhaps red loctite would be wise?
also make sure your pickup isn't coming off.
Old Jun 3, 2006 | 04:53 AM
ede's Avatar
ede
i use loctite on the bolt and an impact or wrench to tighten the bolt
Caspar
Jun 19, 2016 11:19 PM
LT1Formula
Nov 16, 2015 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
