Need Cam Mark Verification...
Old Jun 2, 2006 | 08:50 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
Ok so I have been working on my used 305 i bought to replace my blown 305, neways i got it all together today in a rush to beat the rain, when i put the timing chain in this was my procedure...
I put the cam in, dropped the lifters, and p/rods in, then i turned the motor over to TDC, at this position the crank sprocket was at 12 o'clock and the keyway was at like 2 or 3 o'clock...
Then i put the cam sprocket on, and chain so all in all, My crank sprocket is ar 12 o'clock, and my cam sprocket is at 12 o'clock... From here i dropped the dis. in and re did the firing order from there....
The motor is in now, so please tell me my cam timing is correct???
Last edited by 1986Sleeper; Jun 2, 2006 at 08:55 PM. Reason: Automerged Doublepost
Old Jun 2, 2006 | 08:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's fine. It's easier to line up with the cam sprocket dot at 6 o'clock and the crank dot at 12 o'clock though.
Old Jun 2, 2006 | 08:59 PM
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
One more
One more question, i have one of those chrome timing covers, and the chrome marker... Now with my crank at 12 o'clock why didnt my balancer line match up? I noticed this on the other motor to, i just made a new line on the balancer... I know the 2 piece balancers are known to slip but i know it didnt? Any thoughts????
Old Jun 2, 2006 | 09:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The mark on the factory balancer is for use with a timing comb in about the 12:00 position. Aftermarket timing covers usually have the timing comb in the old 2:00 position.
Old Jun 2, 2006 | 09:09 PM
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
deff. makes sence... thanks for the answers...
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
NiG
Sep 7, 2015 11:25 PM
