ignition problem
Old Jun 4, 2006 | 09:01 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
ignition problem
just completed an engine swap in my 86 iroc, put it all back together and it doesnt start, timing was off, now its close cause it was just barely running just sputtering then died. firing order is correct checked it twice getting fuel, im thinking my coil in the HEI is bad. Its straight carb no computer or that ****. anyone have any ideas?
Old Jun 4, 2006 | 09:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just a dumb suggestion but did you try to adv/ret the timing?
Old Jun 4, 2006 | 10:56 PM
nascar2496's Avatar
Engine: 305 tpi
yeah moved the dist several times in either direction, it just goes down hill from there.
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
