Fuel pump harness install and routing
Old Jun 8, 2006 | 08:31 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi all,
I'm retro fitting a TPI system into my car and I'm at the point where I can install the fuel pump harness inside the car. Because my car was originally carbed I don't have a harness there already.
I have the harness out of a donor car and I need to cut a square hole for the fuel pump socket to go into just behind the back seats. The question is, where is a good location to make this square hole? Does someone have a picture or something of the stock location? I have the entire fuel pump assembly also from a donor car so the harness that comes from the pump assembly obviously has to reach to where this hole gets made in order to connect with the fuel pump harness socket.
Also, how close is the front of the fuel tank to the body of the car? I don't wanna start drilling holes if the fuel tank is very close behind it!
Old Jun 11, 2006 | 04:54 PM
Car: 1989 Trans Am
Too hard a question huh?
Old Jun 11, 2006 | 07:39 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Nope. Just can't find a good picture...
Old Jun 12, 2006 | 04:56 AM
Car: 1989 Trans Am
Any picture you might have would be gratefully received.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
