push rods problem
Old Jun 9, 2006 | 03:07 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
push rods problem
My friend is building his own engine and has ran into a problem with his vavletrain. I helped him install the cam and lifters and pushrods, I then installed the heads and rockers and found out the push rod can move up and down about 1/8 inch. I was thinking about lifters having to build up oil in them. This engine is somewhat of a hybrid lol, its a 2bolt main 81 block 350, with L98 heads. I was hoping if someone thinks i should get longer pushrods or whatnot. I also thought that it might be from going from a rollor cam to a flat tappet camshaft. we are using the lifters that came with the L98 heads. I told him that he should just get new pushrods but i dont know what length he should get them.
Old Jun 9, 2006 | 03:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you went from a roller cam to a flat tappet, then absolutely you need new pushrods. Use an adjustable pushrod to find out the length you need.
Old Jun 10, 2006 | 01:33 AM
3rd gen V8's Avatar
cool thanks for the help i will tell him to get a adjustable pushrod. and i hope that this will solve our problem when we find what length we need to get them. do you think that the push rods might need to be custom and if so how much do you think it will cost to order a set?
Old Jun 10, 2006 | 01:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pushrods are available off the shelf in .100" increments. Cost is pretty much the same regardless of length.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Reborn756
Sep 4, 2015 03:42 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
