Stuttering and hesitation?
Old Jun 12, 2006 | 01:37 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Well I got on here tonight to learn how to check my error codes because the car was hesitating when I gave it gas, and I often got the "service engine soon light." SO.....
I checked the trouble codes and got "flash, pause, flash flash flash" which i assumed was code 13. I decided to check the car one last time, and i unplugged the battery for 30 seconds to clear the codes. I ran it for about 30min, still with the hesitation. Although now I have a new problem. Whenever I stopped the car, the rpms dropped low, like 250-500. I even had the car stall once (its an automatic). I started the car and went up the road about a mile to the next stop light and the rpms dropped low again. I gave it gas and it sputtered and stuttered for a good 30 yards then it hooked up and went like nothing was wrong. I limped it home after that.
Didn't get one single "service engine light".
So finally I checked it for any more errors and I got the "flash, pause, flash flash" over and over again. I assumed that meant "no error" since i never got a "service engine light".
Any idea what is going on?
1991 Camaro RS 3.1l V6 auto
Any suggestions would be greatly appreciated!
Old Jun 12, 2006 | 01:41 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Not sure about the SES light? I'm not the best mechanic
But, if it is acting up when you hit the gas, I would check the fuel filter &
fuel pump. It sounds similar to the problem I had a few years ago... turned out my pump was failing.
If both of those turn out fine, I would check the Throttle Position Sensor (TPS)
and look for vacuum leaks.
Hope this helps.
Best of luck!
Old Jun 14, 2006 | 10:50 AM
draco's Avatar
Engine: 5.0l TBI
well I hollowed out the catalytic converter, ran a brand new tailpipe, and hooked up a new flowmaster exhaust. The hesitation isn't bad now, but i think it is still noticeable. I'm going to change the O2 sensor next and see what it does....
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
