Fuel rail question TPI
Old Jun 12, 2006 | 05:16 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Ok, on the passanger side of the fuel rail, there is a fuel pressure check valve. I have no cap for the valve and upon inspection I see its just a hole. Is there supposed to be a valve core or needle valve of some sort in it? Where can I get a cap for it also??
Old Jun 12, 2006 | 11:55 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
You might try GM Parts Direct: Your direct source for Genuine GM Parts web site.
Also, find a AC Delco dealer in your home town and be very nice to him when you go in, and they might be able to order it for you. I've gotten connectors, memcals, speedo sensors, and gears from the AC Delco dealer in chattanooga. The dealer will just tell you, Not Available.
Old Jun 12, 2006 | 12:42 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The valve core, seal, and cap are sold as a kit. The part number is GM# 17110854. At GMPartsDirect, the shipped price is about $31.
If your fuel rail is on a running engine, I would assume that the schrader valve is intact. There must be a core that you are not seeing.
Old Jun 12, 2006 | 04:46 PM
techno101's Avatar
Car: 1989 Camaro RS
Thanks guys, I'll look to see I can remove the valve on the rail now and inspect it closer. Upon looking down on top of it I don't see any kind of needle or core, I don't have a cap either. Can I install a permanent Fuel Pressure Gauge on this port?
Andrew6.688
Dec 13, 2015 10:59 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
