What does it sound like when a piston hits a valve?
Old Jun 12, 2006 | 08:38 PM
CamaroX84's Avatar
I recently installed 1.6 rockers on my motor, and when I floor it, I hear a weird crunch/pop noise when I shift at around 6000 RPMs. I know sometimes piston/valve clearance can be an issue, so I was wondering what it sounds like when this actually does happen. Thanks.
Old Jun 12, 2006 | 09:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Like a broken engine.
Old Jun 12, 2006 | 09:55 PM
what it sounds like
It sounds REAL EXPENSIVE.
If this sound happens on anything remotely resembling a repetitive basis, it isn't caused by valve-to-piston clearance issues.
Old Jun 12, 2006 | 10:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Expensive is the best answer.
You won't hear a piston hitting a valve however if the piston does hit a valve, there's a very good chance the valve(s) will be bent. You'll then hear noises in the intake or exhaust because the valve doesn't close on the seat.
Going to a higher ratio rocker without checking clearances can bring on other problems. Depending on the cam grind, a higher ratio will give a higher valve lift however if the springs are not designed for the extra lift, they will bind. Also with higher lift, the valve guide needs to be cut down enough so that the bottom of the spring retainer doesn't hit the top of the guide/valve seal.
Spring pressures need to be high enough to keep the valves from bouncing on the seats when they slam closed (valve float). If the valve bounces open when the piston is at or near TDC, it will make contact.
When in doubt, pull your rocker covers off and look for any damage. Broken springs or retainers. Bent pushrods etc. Do a compression or leakdown test to see if the valves are seating.
Old Jun 13, 2006 | 02:34 AM
EvilCartman's Avatar
Car: '82 Z28
Not familier with that cam but if your springs are the same stock springs that came on my AFR 195 heads... They're only rated for .550 lift.
gta90
Sep 15, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
