couple of engine questions
Old Jun 15, 2006 | 01:51 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
hey guys got some more question. i just took the heads of my motor and i noticed a couple of my exhaust valves are white, what would cause this, and is this bad? also what should the top of the pistons look like?mine look kind of a charred black color and seems to be some stuff flaking off them kinda like a cripsy sooty chip or flake not metal or anything.
Old Jun 15, 2006 | 01:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those sound like fairly normal combustion chamber deposits.
All normal
The ones with white exh valves are a bit leaner than the others
Old Jun 15, 2006 | 02:11 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
oh ok as long as everything sounds normal then im happy how would you go about making those other sections richer or is that basically something to live with.
Frozer!!!
Jan 19, 2024 04:55 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
