Rocker studs
Old Jun 15, 2006 | 10:34 PM
tummyson's Avatar
Car: 89 IROC
Transmission: 5 Speed
Axle/Gears: 3.08 Posi
Rocker studs
I've searched and didn't come up with much. Will 7/16" rocker studs work with '081' castings? Is there enough "meat" in the stud boss?
Thanks.
Old Jun 15, 2006 | 10:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you have to use a 7/16" coarse base thread in the casting.
No such thing as a 3/8" THREADED base stud. The stock one that gets pulled out is a press fit 3/8", so that happens to be a nice size to tap for 7/16" so....
the thread for the rocker nut, is where you have the choice, 3/8"NF or 7/16"NF. The 7/16" version obviously being larger and stronger, but you have to get rockers to match.
Old Jun 15, 2006 | 11:16 PM
tummyson's Avatar
Car: 89 IROC
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
355tpipickup
Sep 13, 2015 11:35 PM
