What sensors are what??
Old Jun 18, 2006 | 11:57 AM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
Ok due to recent problems i have been having i would like to get things set straight. What sensors are waht. I know the sensor next to the thermostat is the coolant temp sensor, I think the sensor on the passenger side of the engine at the very bottom is the knock sensor. What i need to know is what are the sensors on either side of the driver and passenger side of the engine located on the heads ??
Old Jun 18, 2006 | 12:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It would be useful to know what engine you have.
Old Jun 18, 2006 | 12:47 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I'm assuming you have a 350 in a rally sport, what year, what setup?
Old Jun 18, 2006 | 01:34 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
It's an 89 RS that had a 305 TBI but I put a 350 in and kept the TBI? Now can you help me??
Old Jun 18, 2006 | 02:12 PM
WickedTA's Avatar
Car: 85 TA
what year of 350 is it? what did it come out of?
Old Jun 18, 2006 | 03:05 PM
Vader's Avatar
TBI should have a MAP sensor mounted to the firewall, a CTS at the front coolant crossover on the intake, A detonation sensor just abouve the RH oil pan mounting rail (block drain), a temperature sending unit in the LH head, and an IAT sensor in the air cleaner housing. The oil pressure sender may be in the LR corner of the case above the oil filter boss, or in the rear intake flange wall depending upon how the retrofit was done.
Old Jun 18, 2006 | 08:11 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
but what is the sensor on the passenger side head between the #6 and #8 exhaust ports??
Old Jun 18, 2006 | 08:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Should be your fan switch.
Old Jun 18, 2006 | 09:26 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
So on the driver head there is a temperature sending unit and on the passenger head there is a fan switch? And next to ther thermostat there is a CTS. So if i were to put on an aftermarket sensor to triggure the fan at a lower temp, i would replace the sensor on the passenger head, Correct?
Old Jun 18, 2006 | 11:08 PM
Car: 87 IROC
Engine: 5.7 TPI
That is the impression that I have been under. I'm planning on getting that switch from jegs, and I was going replace the sensor on the passenger side, right by the plugs.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
