Unstable Idle
Old Jun 19, 2006 | 06:01 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Unstable Idle
What could cause an unstable idle? It's a comuter controlled quadrajet 305. It doesnt have a idle speed motor or anything. could my float be too high? Or is it something else?
Old Jun 19, 2006 | 08:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Could be a vacuum leak - check all the vacuum lines for cracks. Can also check by spraying carb cleaner anywhere vacuum could leak from while engine is running - if you spray it and the idle smooths out or increases, you found a leak. BUT DON"T USE STARTING FLUID for this - starting fluid is too volatile and catches fire too easily.
Old Jun 19, 2006 | 09:06 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok I'll try that as soon as I can.
Old Jun 19, 2006 | 09:49 PM
sean86sc's Avatar
Car: 86 camaro sport coupe
Engine: 355
Get a vacuum pump and check the choke cannister on the side of the carb. And basically everything else related to vacuum.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
