no torque or acceleration!!
Old Jun 22, 2006 | 01:43 AM
billyshizzleyo's Avatar
hi im new here i hope this is the right place for this...
well anyway about 2 days ago i got a 91 firebird and it has noo torque at all!! it takes forever to get up to speed.
when its cold, after i first start it it has power untill it warms up. i put new plugs, wires, dist cap, air filter, changed the oil and filter, checked the atf and thats good...
i just dont have a clue what it could be...does anyone have any ideas on what it could be??
please help me..im getting passed by soccer moms on the highway!!!!
Old Jun 22, 2006 | 12:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
getting any codes?
how many miles on the car?
what motor in the car?
bone stock, as far as you know?
Old Jun 22, 2006 | 12:56 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Does it have the 3.1 motor in it? That might explain why soccer moms are passin you on the freeway...
Old Jun 26, 2006 | 01:40 AM
25th rs camaro's Avatar
Car: 1992 Camaro Rally Sport
Engine: L03 305 E TBI
Transmission: M5
Axle/Gears: 3.08
if you dont know how to pull the codes do a
Old Jun 26, 2006 | 11:40 AM
Vader's Avatar
Welcome Aboard!
Knowing the engine/trans combo might help.
Since it has noticably more power when cold, we can probably rule out a restricted exhaust. We can probably also rule out fuel pressure/delivery problems (at least from the pump). Your ignition system is probably in reasonably good condiotion now, but you might want to test the coil and HEI module when they are hot.
Commonly, fuel mixture is leaner once the engine reaches operating temperature and the ECM achieves Closed Loop Mode. As coolant temperature increases further, mixture gets even leaner, then ignition timing begins to retard. What is the indicated coolant temperature after it has fully warmed?
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
