Power Steering
Old Jun 22, 2006 | 07:42 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Power Steering
Below is a picture of a Power Steering Pump the same as the one in my car. I am trying to pick up a pulley but the ones I see for sale are listed as "Press Fit or "works with a keyway". What does it mean works with a keyway. Which one is the below pulley can anyone tell me.
Thanks.
Old Jun 22, 2006 | 07:58 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
all the ones that I've seen are press-fit, a key way means there is a grove in the shaft and on the pulley that a small flat rectangular or half circle shaped piece of metal called a "key" fits into, that joins the shaft and pulley together, a good example is the end if a crankshaft, there is a "woodruff key" (half circle one) in it that fits into the crankshaft, and then into the timing gear and the harmonic balancer.
Old Jun 23, 2006 | 07:58 AM
gholian's Avatar
Engine: 2.8 V6
Thanks for the explanation.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
