car running ruff smelling gas?
Old Jun 23, 2006 | 05:46 PM
CamaroJosh1000's Avatar
Car: 88' Chevy. Camaro Iroc-Z
Transmission: Manual 5-speed
so i just bought an 88' 305 tpi. Car was running great until a couple days ago when i filled up the tank. As soon as i started the car i could feel the differece in the motor. it is idiling around 750 if that right i dont know. Plugs seem fine car is getting gas but smells like its running to rich.? ?
Old Jun 24, 2006 | 09:02 AM
Vader's Avatar
Any error codes? Since you've checked plugs, did you also check wires, cap, and rotor? Is the 750 RPM idle in gear or neutral?
Old Jun 24, 2006 | 03:48 PM
in gear and out of gear. got codes 32 33 and 35 thinking its the MAP sensor. Where is that stupid thing located on the motor?????
Old Jun 24, 2006 | 04:09 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
88 TPI were not MAP equiped. They have a MAF on the intake ducting right before the throttle body.
bryan623
Mar 22, 2021 06:43 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
