External fuel pump location
Old Jun 26, 2006 | 08:57 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I just installed a sumped fuel tank in my 1987 Z-28. The muffler would no longer work because it contacted the sump. I modified the exhaust to clear the sump (deleted the muffler). My question is: Where is everyone putting their in-line fuel pumps? It is tight under there. I know the fuel pump should be lower than the sump and as close to the tank as possible, but I really don't see how I can do that.
For those that have in-line fuel pumps, could you please post pictures. Also, how critical is it that it be close to the sump and below it?
Also, I am using a Mallory 110FI fuel pump which is a verticle mount pump rather than a horizontal pump. I have included a picture of the area, so anyone with suggestions can chime in.
Old Aug 1, 2006 | 12:35 PM
JesasaurusRex's Avatar
I put mine behind the rear seat area
Old Aug 1, 2006 | 01:14 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
Thanks, that is where I ended up putting it.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
