Help Quick
Old Jun 30, 2006 | 12:50 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Help Quick
Alright guys,
Ive had the car running fine for awhile, and something
funny is going on, not too horrible ..but still nerve racking
Anyway, my oil press. gauge is pinged at 60lbs+, lol ..
I have no clue why, even with the engine on/off its the
same reading.. does this indicate a bad sender? faulty
wiring? I pretty sure its the green wire comming off the
wiring harness ..its looks intact, and so does the sender.
..but that doesnt mean there is nothing wrong with it
If I cant get the sucker to work, Im going to get a
mechanical gauge for accuracy and less headaches ..
Ill try to take pics with the cell phone
Any thoughts??
Old Jun 30, 2006 | 04:53 AM
rezinn's Avatar
Bad sender. It does that when it isn't connected, too.
Old Jun 30, 2006 | 04:56 AM
TPI's Avatar
Well I was a bit confused at first ..
What is the sensor unit on the rear of the block behind the intake??? Kinda bulgy looking and shiny tin metal of some sort.. I had that confused with the other sender down below ..
The actual sender appears to be bad, leaking oil and shows wear and age, but .. what the heck is that otherthing on the rear of the block?
*Edit* I can take a cell phone pic of it, Its a
cylindrical sensor with a male electical fitting on
the end of it, not sure what it is ..
Thanks for the reply
Old Jun 30, 2006 | 04:48 PM
TPI's Avatar
What Is this thing ?? This is the "humdinger" that I got confused
with my Oil pressure sender
and Here is the actual oil pressure sender down below,
It looks worn and old... And should be replaced
**All pics are on cellphone and appear to be mirrored
Old Jun 30, 2006 | 05:41 PM
TPI's Avatar
Originally Posted by TPI
What Is this thing ?? This is the "humdinger" that I got confused with my Oil pressure sender
No one knows what that 'Humdinger' is??
I obviously figured out what's wrong with the oil press. sender, but That still doesnt ease my mind untill I figure out what that sensor is behind my plenum ..
I figured pics would provoke a quick response ..
I guess not
Old Feb 17, 2010 | 01:24 PM
1987-iroc-z383's Avatar
Car: 1987 chevrolet camaro Iroc-z
Engine: 383 tpi
Transmission: built 700r4
Axle/Gears: posi 3:45
Re: Help Quick
oil pressure switch
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
