vacume leaks galore
Old Jul 5, 2006 | 03:34 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
vacume leaks galore
Anybody ever had this problem or can you offer some assistance.My tpi 350 IS ALL NEW,BESIDES THE TPI set up that came off my 305.I am haveing vacume leaks at the intake,runners and cold start injector.One of my cylinders seems to not be firing.Could that because of the vacume leaks.We have put new gaskets on it three times and the last time we put silicone on both sides of the gaskets and the surfaces to try to get it to seal and then let it sit 24 hours and it's still leaking.Anybody know why or whats up?I just want to drive my damn car!I'm about ready to say f*** it and carb it.What all would i need to get besides a intake and carb,and which ones would be the best with my set up?Help!!!
Old Jul 6, 2006 | 04:17 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
well it seems we got the vacume leaks under controll but number 4 cylinder is a dead hole.Checked injector its getting power.Havent pulled it yet but will if i have to.Checked springs and everything looks fine.I,m stumped and mad. any body got a clue
Old Jul 6, 2006 | 04:25 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
bad plug or wire? Maybe even the terminal in your dizzy might be damaged. Start with the basics first
Old Jul 6, 2006 | 04:52 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
plugs look fine msd wires are brand new.GOING TO CHECK THE IGNITION WIRES AND COIL BUT IT ALL SHOULD BE FINE BUT I'LL SEE
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
