tbi fuel question
Old Jul 8, 2006 | 08:42 AM
MiZZiE's Avatar
Car: '88 camaro/ '89 gmc s15 lower'd.
Engine: 305tbi 5.0 & 4.3v6 soon to be 350.
Transmission: 5spd manual/camaro.. auto/s15
tbi fuel question
trying to get my 88 305 tbi running and have a question.
it's an 88 camaro 5spd 305v8 TBI, car was sitting for a while, when i went to start it for the first time in a while it turned over but didnt start, when i sprayed starter fluid directly into the injector area it started then died, so i had an idea LOL and had my girlfriend turn it over while i kept spraying fluid in it and it stayed running no problem and sounded great WHILE i was spraying fluid into it, but as soon as i stopped, the motor died.
I have a fuel fliter i plan on putting in but i dont think thats the whole problem because even if ts clogged it would still supply a little gas to the motor, or no?? how can i check if my fuel pump is dead without a pressure guage? if i hear it kick on does that mean its good? also could the problem be old gas, it had about 5 gallons of old gas in it and i was told if i filled it up with new good quality gas that it would all mix together (sort of concentrate itself into the old gas), i don't think it worked like they thought...
let me know some things to try because she runs, and sounds beautiful-- untill i stop directly feeding it gas or starter fluid... confused... please help
also the car is for sale as is because i never had the time to get it going but i want to get it running because its a beauty and i want to drive it before i sell it, and if i get it running ill most likely keep it. LOL
thanks,
-,Mike
Old Jul 8, 2006 | 04:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you can rent a fuel pressure gauge I think. Hook it up and crank the car over, and watch the gauge. If it shows ok, then leave that alone. I doubt it though, I think you'll notice in the range of 0 pressure, hence getting you to replace the pump... Just my guess though.
"old gas"? Care to explain? How long was the car parked? I think the fuel filter should be replaced either way, it *could* be completely plugged up.
Old Jul 8, 2006 | 05:22 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Switch out that piece of **** tbi unit with a carb setup!
That would solve your issue and really wake your engine up
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
