Whats a IAC?
Old Jul 8, 2006 | 07:08 PM
iroc240_3's Avatar
Whats a IAC?
What is it and how do you clean it? I saw this as a cure for a rogh idle in another thread..
Old Jul 8, 2006 | 07:38 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
IAC = Idle Air Control (motor). It controls, acording to computer commands, the Idle speed. As loads increase on the engine at idle, the computer opens the IAC to keep the idle speed at the constant programmed speed. As loads decrease, the computer commands the IAC to close until the programmed speed is obtained. Rough idle caused by the IAC, I'm not sure, unless it doesn't work all together.
Old Jul 8, 2006 | 07:43 PM
iroc240_3's Avatar
Thanks for the info
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
