Flat tappet cam with roller lifters???
Old Jul 9, 2006 | 12:31 AM
boredomkills's Avatar
Car: 1992 rs
Engine: 350 tbi
Is there any reason that i could not run a a cam designed for flat tappets with a roller lifter? My block is a roller block and i can get a flat tappet cam from a friend for a good price and it is about what i am looking for with lift and duration.
Old Jul 9, 2006 | 01:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The lobes on flat tappet cams are tapered.
Old Jul 9, 2006 | 05:31 AM
ede's Avatar
ede
if you don't mind the end results there's no reason you couldn't do it, on the other hand if you didn't want to would be reason enough not to do it. there's a reason one's a flat cam and one's a roller, they don't mix and match. there is no reason you can't run a flat cam and lifters in a roller block without problems.
Old Jul 9, 2006 | 06:15 AM
cbd1's Avatar
Car: 89 Formula
Engine: LB9
Transmission: MM5
Axle/Gears: G80/GM3
I don't build any motors without roller cams these days. The power under the curve is just too much better with the roller profiles. Hell, plug them both into desktop dyno (not super accurate, but not too bad for cheap). I seriously doubt you'd be happy with the tradeoff anyway. 2c
Old Jul 9, 2006 | 01:10 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Yes, there is a good reason, the cam WILL be destroyed in very short order, flat tappet cams have a taper on the lobe designed to make a flat lifter rotate, a roller lifter roller is flat, so the lifter will be contacting the lobe on a tiny point and will quickly wipe out the cam. just spend a little more money and get the proper roller cam for it, thay can be bought cheaply on e-Bay.
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
