Smog Question
Old Jul 9, 2006 | 01:55 PM
Blktalon456's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: T5 5 Speed
Axle/Gears: 3.08 LS
Smog Question
Is it possible to remove the smog pump and emission hoses from the manifolds and the car still run properly? I believe you can just want to be sure. Thanks again for the info
Old Jul 9, 2006 | 02:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can, you'll just have to plug off the connections where the exhaust gases normally would flow (the ports on the manifolds, the tube from the cat converter, etc.). But there's no hp gains from such on an otherwise stock ride.
Plus, although emissions testing is out for 3rd gens now in NC, many inspection shops will still look for the equipment to be in tact, as legally it is "supposed" to remain - you'll have to find an inspector that won't crack the hood if you do so (which isn't that hard - I swapped my 1992 over to a carbed 350 with no emissions equipment at all, and haven't had a problem).
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 7, 2015 09:55 PM
