fuel pump dead, but no code?
Old Jul 10, 2006 | 05:03 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my car died on me the other day, it gets no fuel. pump doesnt prime when i put it in ACC.
thats all well and good, either a wiring problem or a bad pump. my problem is, when i hooked up my scan tool to it, or when i put the car in ACC without it plugged in, i get no service engine light at all. im almost positive it worked up until my fuel pump quit working. is it possible my ecm went bad, somehow not making that light come on, and giving no signal to the pump at the same time? can i check this to confirm or deny?
other than this, as far as i can tell there is no problem with the car.
Old Jul 10, 2006 | 01:33 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Might want to check all your fuses and fusable links.Start there if all looks good you might check power to and from your ECM.If that looks good then inspect the SES bulb and see if its blown.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
