Oil change question
Old Jul 10, 2006 | 01:17 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Oil change question
I know with changing oil and all that your supposed to heat the car up before changing the oil and filter. Well because I planned on having my car sit while I was at college, I took out a lot of the stuff in it, including the entire ignition system. My question is, is it still necessary for me to put all that back in, start it up, then change the oil or is there some way I can get around having to start it?
Old Jul 10, 2006 | 01:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Just change it as is. Everything will have settled nicely.
Changing oil on a hot car is no fun at all.
Old Jul 10, 2006 | 01:24 PM
j dezzy's Avatar
Car: 87 TA
heating the car up just helps thin out the oil so that all the loose crap in there comes out and doesn't stick around. so yup...it'll be fine to change it cold after sitting for a while. I wouldn't want to run a car on old crappy oil anyways.
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
