Cat and emmissions
Car: 1989 IROC
Transmission: t5, wanna be a t56 when I grow up!
Axle/Gears: Whatever stays bolted on behind me!
Cat and emmissions
If a cat is going bad, or already there, would both CO and HC be unusually high? My HC is slightly out of range, where as mey CO is very high.
Would a dirty air filter cause CO's to be that high?
Im trying to rule everything else out, before I assume cat. Ive done plugs, cap, rotor, and clean air filter. I want to also check FP and replace O2 sensor. TPS is good and was within range.
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
LT1Formula
Oct 8, 2015 08:34 PM
