Couple of Questions
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Couple of Questions
Hey Guys, I have a couple of questions. First I have a High mileage engine (215,000 kms) It still goes strong and sounds great. But I was wondering if I should bother doing an engine flush with the next oil change or will it ruin a good thing. Also I run synthetic in it since I bought the car about 10 yrs now, but I was also wondering if I should bother with the high milage synthetic or just the normal should be fine.
Darrell
Darrell
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Darrell
Darrell
I have no personal experience with the high mileage synthetic against the normal synthetic, but personally I'd probably just keep running the same stuff.
Car: '92 firebird
Engine: 305tbi
Transmission: th350
Axle/Gears: moser 28 spline 3.73 eaton posi
yeah, probably stick with the oil you're using. I don't know of any problem that changing type of oil will fix, anyway(oil is for lubrication and cooling, not designed to keep itself from leaking.......)
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Its just the stuff in a bottle that you put in before the oil change and it is suppose to clean up the buildup in the engine. I was just wondering if I should bother because the engine seems to be working pretty good. I have no leaks or anything, I just seen the higher mileage synthetic on the shelf and was wondering.
Darrell
Darrell
Transmission: 4L80E/4L80E
What oil have you been using?
The "high mileage formula" oils are 95% marketing ploy. Do you want to be a pawn in that game?
