vortec heads intake on, alternator bracket doesnt line up?
Old Jul 12, 2006 | 08:37 AM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
anyone else have this problem?
i had the original 305 with Vbelts in my camaro, then swapped it to a 355, i want to use the same vbelt set up, but it seems like the alternator bracket is WAY off with the holes on the intake
what do i need to do?
Old Jul 12, 2006 | 12:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
cut off that section of the bracket, I no longer use the part that bolts to the intake and rather cut if off with a cut off saw flat down the edge and painted it black.
Old Jul 12, 2006 | 12:50 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
it depends...
are you using the stocker bracket? an aftermarket manifold is usually thicker and thnner in certain places, dont count on it being an exact fit, sometimes with those stocker brackets, spacers are needed, and well, forcing things to work... stock a long bolt in there and pull the bolt holes together...
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
